<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-how-to-convertible-care-adjustments-and-tips-831.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-faqs-regarding-the-re-sleeving-of-ls1-ls6-engine-blocks-with-the-darton-mid-sleeve-kit-815.html</guid>
										<title>1997 - 2004 Corvette: FAQs Regarding the Re-sleeving of LS1/LS6 Engine Blocks with the Darton MID Sleeve Kit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-faqs-regarding-the-re-sleeving-of-ls1-ls6-engine-blocks-with-the-darton-mid-sleeve-kit-815.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-how-to-power-antenna-replacement-829.html</guid>
										<title>1997 - 2004 Corvette: How-To:  Power Antenna Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-how-to-power-antenna-replacement-829.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-headlamp-actuator-replacement-procedure-814.html</guid>
										<title>1997 - 2004 Corvette: Headlamp Actuator Replacement Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-headlamp-actuator-replacement-procedure-814.html</link>
