<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l-98-engine-start-sequence-802.html</guid>
										<title>1985 - 1991 Corvette: L-98 Engine Start Sequence</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l-98-engine-start-sequence-802.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1982-corvette-how-to-bleeding-brakes-830.html</guid>
										<title>1965 - 1982 Corvette: How-To: Bleeding Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1982-corvette-how-to-bleeding-brakes-830.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-install-vette-brakes-spreader-bar-in-a-c3-corvette-809.html</guid>
										<title>1968 - 1982 Corvette: How to install Vette Brakes Spreader Bar in a C3 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-install-vette-brakes-spreader-bar-in-a-c3-corvette-809.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-replacing-rear-wheel-bearings-806.html</guid>
										<title>1995 Corvette: Replacing Rear Wheel Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-replacing-rear-wheel-bearings-806.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-repairing-driver-side-sun-visor-807.html</guid>
										<title>1981 Corvette: Repairing Driver Side Sun Visor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-repairing-driver-side-sun-visor-807.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-rotor-bearing-installation-812.html</guid>
										<title>1963 - 1982 Corvette: Rotor Bearing Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-rotor-bearing-installation-812.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-how-to-tpi-fuel-rail-removal-fuel-injector-replacement-827.html</guid>
										<title>1982 Corvette: How-To: TPI Fuel Rail Removal (Fuel Injector Replacement)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-how-to-tpi-fuel-rail-removal-fuel-injector-replacement-827.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-fixing-erratic-digital-display-804.html</guid>
										<title>1990 - 1996 Corvette: Fixing Erratic Digital Display</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-fixing-erratic-digital-display-804.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-re-dyeing-seats-813.html</guid>
										<title>1984 - 1996 Corvette: Re-Dyeing Seats</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-re-dyeing-seats-813.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-installing-c4-corvette-seats-in-a-c3-corvette-810.html</guid>
										<title>1968 - 1982 Corvette: Installing C4 Corvette Seats in a C3 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-installing-c4-corvette-seats-in-a-c3-corvette-810.html</link>
