<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-fixing-erratic-digital-display-804.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-air-filter-replacement-803.html</guid>
										<title>1993 Corvette: Air Filter Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-air-filter-replacement-803.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-increasing-instrument-cluster-illumination-805.html</guid>
										<title>1984 Corvette: Increasing Instrument Cluster Illumination</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-increasing-instrument-cluster-illumination-805.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-replacing-rear-wheel-bearings-806.html</guid>
										<title>1995 Corvette: Replacing Rear Wheel Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-replacing-rear-wheel-bearings-806.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l-98-engine-start-sequence-802.html</guid>
										<title>1985 - 1991 Corvette: L-98 Engine Start Sequence</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l-98-engine-start-sequence-802.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-re-dyeing-seats-813.html</guid>
										<title>1984 - 1996 Corvette: Re-Dyeing Seats</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-re-dyeing-seats-813.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</guid>
										<title>1968 - 1982 Corvette: How-To: TPI for a C3: A couple things that worked well for me over the years</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-how-to-tpi-for-a-c3-a-couple-things-that-worked-well-for-me-over-the-years-828.html</link>
