<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-audible-noise-in-radio-chevrolet-with-transistorized-ignition-80.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</guid>
										<title>1967 Corvette:  Chevrolet PartsMart:  Fusible Links</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-chevrolet-partsmart-fusible-links-1139.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</guid>
										<title>1955 - 1964 Corvette:  Chevrolet PartsMart:  Bulb and Fuse Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-rear-bulb-re-incarnation-243.html</guid>
										<title>1966 Corvette: Technical Article:  Rear Bulb Re-incarnation</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</guid>
										<title>1966 Corvette:  Service News: Corvette Radio Speaker - Replace</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-news-corvette-radio-speaker-replace-50.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</guid>
										<title>1964 Corvette:  Service News:  Servicing the Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Distributor Breaker Point Burning</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-distributor-breaker-point-burning-54.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-directional-signal-switch-service-886.html</guid>
										<title>1964 Corvette:  Service Bulletin:  Directional Signal Switch Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-directional-signal-switch-service-886.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-electric-window-motor-replacement-846.html</guid>
										<title>1967 Corvette: Service News: Corvette Electric Window Motor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-electric-window-motor-replacement-846.html</link>
