<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-oil-filter-with-incorrect-label-21.html</guid>
										<title>2014 Corvette:  Techlink Article: Oil Filter with Incorrect Label</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-oil-filter-with-incorrect-label-21.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Setting the Timing on Gen 5 V6 and V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-techlink-low-oil-pressure-conditions-1407.html</guid>
										<title>2015 - 2019 Corvette:  TechLink:  Low Oil Pressure Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-techlink-low-oil-pressure-conditions-1407.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-low-oil-pressure-message-light-inspect-valve-lifter-oil-filter-1298.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: Low Oil Pressure Message/Light - Inspect Valve Lifter Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-low-oil-pressure-message-light-inspect-valve-lifter-oil-filter-1298.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</guid>
										<title>2017 Corvette Z06: GM TechLink: Supercharger Idler Pulley Sounds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin: #PIP5179D: Extended Crank Cold With DI (Direct Injected) Engines - (Mar 27, 2018)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</guid>
										<title>2014 - 2015 Corvette:  Service News:  Engine Repair with Crankshaft Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
