										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</guid>
										<title>1998 - 2004 Corvette:  Press Release: Active Handling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2004-corvette-press-release-active-handling-system-441.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</guid>
										<title>2003 Corvette:  Technical Article:  Magnetic Selective Ride Control - First Ride</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-selective-ride-control-first-ride-443.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/road-test-active-handling-corvette-s-revolutionary-new-option-increases-safety-and-performance-440.html</guid>
										<title>Road Test: Active handling: Corvette`s revolutionary new option increases safety and performance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/road-test-active-handling-corvette-s-revolutionary-new-option-increases-safety-and-performance-440.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-ride-star-wars-meets-the-50th-car-444.html</guid>
										<title>2003 Corvette: Technical Article: Magnetic Ride - Star Wars Meets the 50th Car</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-technical-article-magnetic-ride-star-wars-meets-the-50th-car-444.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</guid>
										<title>2003 Corvette: Service Bulletin: Info - New Vehicle Preparation for Magnetic Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-service-bulletin-info-new-vehicle-preparation-for-magnetic-selective-ride-control-445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-recall-lower-control-arm-ball-stud-washer-442.html</guid>
										<title>2004 Corvette: Recall: Lower Control Arm Ball Stud Washer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-recall-lower-control-arm-ball-stud-washer-442.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2000-corvette-service-bulletin-smu-deletion-of-variable-effort-steering-description-447.html</guid>
										<title>1999 - 2000 Corvette: Service Bulletin: SMU - Deletion of Variable Effort Steering Description</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2000-corvette-service-bulletin-smu-deletion-of-variable-effort-steering-description-447.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-manual-update-revised-wheel-drive-shaft-outer-joint-and-seal-replacement-and-wheel-drive-shaft-inner-joint-and-seal-replacement-procedures-446.html</guid>
										<title>2001 - 2003 Corvette: Service Manual Update: Revised Wheel Drive Shaft Outer Joint and Seal Replacement and Wheel Drive Shaft Inner Joint and Seal Replacement Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-manual-update-revised-wheel-drive-shaft-outer-joint-and-seal-replacement-and-wheel-drive-shaft-inner-joint-and-seal-replacement-procedures-446.html</link>
