<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-automatic-transmission-fluid-783.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Transmission Identification Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</guid>
										<title>1961 Corvette:  Service Bulletin:  3-Speed Transmission Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-new-spoke-flywheel-and-converter-attachment-to-flywheel-late-powerglide-models-791.html</guid>
										<title>1953 Corvette: Service Bulletin: New Spoke Flywheel and Converter Attachment to Flywheel - Late Powerglide Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-new-spoke-flywheel-and-converter-attachment-to-flywheel-late-powerglide-models-791.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</guid>
										<title>1953 - 1954 Corvette:  Service News:  Powerglide Clutch Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</guid>
										<title>1962 - 1963 Corvette:  Service Bulletin:  Governor Rattle After Reverse Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-chevrolet-advance-information-new-clutch-pressure-plate-released-for-1962-corvette-1044.html</guid>
										<title>1957 - 1962 Corvette:  Chevrolet Advance Information:  New Clutch Pressure Plate Released for 1962 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-chevrolet-advance-information-new-clutch-pressure-plate-released-for-1962-corvette-1044.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Vacuum Modulator Spring Throttle Valve Inner Spring</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-conversion-from-3-speed-to-4-speed-transmission-787.html</guid>
										<title>1956 - 1957 Corvette: Service Bulletin: Conversion From 3-Speed to 4-Speed Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-bulletin-conversion-from-3-speed-to-4-speed-transmission-787.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-hard-shifting-1216.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Hard Shifting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-hard-shifting-1216.html</link>
