<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1955-corvette-service-bulletin-distributor-dust-contamination-782.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-directional-signal-malfunction-94.html</guid>
										<title>1959 Corvette: Service Bulletin: Directional Signal Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-directional-signal-malfunction-94.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-news-fuel-gauge-diagnosis-1050.html</guid>
										<title>1971 Corvette: Service News:  Fuel Gauge Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-news-fuel-gauge-diagnosis-1050.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-correction-for-erratic-tachometer-operation-952.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Correction for Erratic Tachometer Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-correction-for-erratic-tachometer-operation-952.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</guid>
										<title>1955 - 1964 Corvette:  Chevrolet PartsMart:  Bulb and Fuse Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</guid>
										<title>1955 - 1959 Corvette:  Chevrolet PartSmart:  Distributors and Starter Motors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</guid>
										<title>1965 Corvette:  Service News:  Vent the Window Regulator Motor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Temperature Gauge Erratic During Normalizing Period</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Generator Belt Misalignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-1955-corvette-service-bulletin-positioning-directional-signal-flasher-plastic-socket-781.html</guid>
										<title>1954 - 1955 Corvette: Service Bulletin: Positioning Directional Signal Flasher Plastic Socket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-1955-corvette-service-bulletin-positioning-directional-signal-flasher-plastic-socket-781.html</link>
