<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</guid>
										<title>1955 - 1957 Corvette: Service Bulletin: V-8 Distributor Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-delco-radio-service-parts-1041.html</guid>
										<title>1960 - 1961 Corvette: Service Bulletin: Delco Radio Service Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-delco-radio-service-parts-1041.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-spark-plug-changes-178.html</guid>
										<title>1957 Corvette: Service News: Spark Plug Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-spark-plug-changes-178.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Front and Rear Door Glass Loose in Run Channels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-front-and-rear-door-glass-loose-in-run-channels-1158.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-water-leaks-corvette-doors-236.html</guid>
										<title>1953 - 1954 Corvette: Service Bulletin: Water Leaks - Corvette Doors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-water-leaks-corvette-doors-236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</guid>
										<title>1959 Corvette:  Service Bulletin Board - Parts Mart Magazine - Tune-Up Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Temperature Gauge Erratic During Normalizing Period</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Generator Belt Misalignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-generator-belt-misalignment-1181.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-directional-signal-malfunction-94.html</guid>
										<title>1959 Corvette: Service Bulletin: Directional Signal Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-directional-signal-malfunction-94.html</link>
