<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Crankcase Breather Assembly (Cap)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</guid>
										<title>1957 - 1962 Corvette:  Rochester Fuel Injection Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-improved-harmonic-balancer-attachment-93.html</guid>
										<title>1962 Corvette: Technical Information:  Improved Harmonic Balancer Attachment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-improved-harmonic-balancer-attachment-93.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</guid>
										<title>1960 - 1961 Corvette:  Service Bulletin:  Corvette Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-calibration-891.html</guid>
										<title>1959 Corvette:  Service News:  Fuel Injection Calibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-calibration-891.html</link>
