<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-loss-of-oil-pressure-176.html</guid>
										<title>1962 Corvette: Service Bulletin: Loss of Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-loss-of-oil-pressure-176.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</guid>
										<title>1957 Corvette: Service Bulletin: Automatic Choke Piston Inoperative Due to Carbon Deposits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</guid>
										<title>1957 Corvette: Service News: Fuel Injection Pump Drive Shaft Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</guid>
										<title>1959 Corvette:  Service News:  Fuel Injection Pump Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</guid>
										<title>1959 Corvette:  Service Bulletin Board - Parts Mart Magazine - Tune-Up Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</guid>
										<title>1958 Corvette: Service Bulletin: Siphon Breaker Plate Unit #7014900 Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</link>
