<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</guid>
										<title>1953 - 1954 Corvette:  Service News:  Powerglide Clutch Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-news-powerglide-clutch-interference-1168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</guid>
										<title>1958 - 1959 Corvette: Service Bulletin: Vacuum Modulation System Inspection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1959-corvette-service-bulletin-vacuum-modulation-system-inspection-784.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</guid>
										<title>1956 Corvette Service Bulletin:  Clutch Disc - Springs - Periodic Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Upshift at Part Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Transmission Identification Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-chevrolet-advance-information-new-clutch-pressure-plate-released-for-1962-corvette-1044.html</guid>
										<title>1957 - 1962 Corvette:  Chevrolet Advance Information:  New Clutch Pressure Plate Released for 1962 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-chevrolet-advance-information-new-clutch-pressure-plate-released-for-1962-corvette-1044.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</guid>
										<title>1961 Corvette:  Service Bulletin:  3-Speed Transmission Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Aluminum Powerglide Shift Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-news-corvette-4-speed-transmission-harsh-shift-into-third-speed-789.html</guid>
										<title>1957 - 1958 Corvette: Service News: Corvette 4-Speed Transmission - Harsh Shift Into Third Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-news-corvette-4-speed-transmission-harsh-shift-into-third-speed-789.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</guid>
										<title>1956 - 1957 Corvette:  Service News:  Corvette Transmission Mount</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</link>
