<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</guid>
										<title>1957 Corvette: Service Bulletin: Automatic Choke Piston Inoperative Due to Carbon Deposits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-temperature-gauge-147.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Temperature Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-temperature-gauge-147.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</guid>
										<title>1957 - 1961 Corvette: Service Bulletin: Oil Consumption Complaints</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</guid>
										<title>1953 - 1958 Corvette: Service Bulletin: Fuel Filter Element Maintenance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-positraction-axle-operation-and-service-1070.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Positraction Axle Operation and Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-positraction-axle-operation-and-service-1070.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</guid>
										<title>1957 - 1963 Corvette:  Service News:  New Fuel Injection Service Kits Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Oil Consumption</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</guid>
										<title>1955 Corvette:  Service Bulletin: Oil Pump Suction Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</link>
