<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1961-corvette-service-bulletin-fuel-pump-diaphragm-leakage-767.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-inter-organization-letters-fuel-injection-issues-1146.html</guid>
										<title>1957 Corvette:  Inter-Organization Letters:  Fuel Injection Issues</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-inter-organization-letters-fuel-injection-issues-1146.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</guid>
										<title>1960 - 1961 Corvette:  Service Bulletin:  Corvette Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-fuel-injection-fuel-meter-pump-drive-shaft-seal-replacement-911.html</guid>
										<title>1959 Corvette: Fuel Injection Fuel Meter Pump Drive Shaft Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-fuel-injection-fuel-meter-pump-drive-shaft-seal-replacement-911.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1960-corvette-factory-letter-rochester-fuel-injection-127.html</guid>
										<title>1958 - 1960 Corvette: Factory Letter - Rochester Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1960-corvette-factory-letter-rochester-fuel-injection-127.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</guid>
										<title>1957 Corvette: Service Bulletin: Automatic Choke Piston Inoperative Due to Carbon Deposits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</guid>
										<title>1959 Corvette:  Service Bulletin Board - Parts Mart Magazine - Tune-Up Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Oil Level Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</link>
