<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</guid>
										<title>1957 Corvette: Service News: Fuel Injection Pump Drive Shaft Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-positraction-axle-operation-and-service-1070.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Positraction Axle Operation and Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-positraction-axle-operation-and-service-1070.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</guid>
										<title>1955 - 1956 Corvette:  Service Bulletin:  Inlet Manifold Oil Guards</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</guid>
										<title>1957 Corvette:  Chevrolet Technical Test Report:  Fuel Economy - Fuel Injection vs. Carburetion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</guid>
										<title>1957 Corvette: Service Bulletin: Automatic Choke Piston Inoperative Due to Carbon Deposits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</guid>
										<title>1962 Corvette: Technical Information: Carter AFB Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</guid>
										<title>1953 - 1958 Corvette: Service Bulletin: Fuel Filter Element Maintenance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</guid>
										<title>1957 - 1962 Corvette:  Rochester Fuel Injection Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</link>
