<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-hydraulic-valve-lifter-adjustments-764.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</guid>
										<title>1962 Corvette: Technical Information: Carter AFB Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Calibration Revised to Correct Lean Condition at Wide Open Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Crankcase Breather Assembly (Cap)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Radiator Core Usage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-radiator-core-usage-1157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</guid>
										<title>1958 Corvette: Service Bulletin: Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</link>
