<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-news-corvette-fuel-injection-760.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Oil Level Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</guid>
										<title>1959 Corvette:  Service News:  Fuel Injection Pump Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</guid>
										<title>1956 Corvette:  Production Information: Mandatory Option 469 Dual Four Barrel Carburetor Equipment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-production-information-mandatory-option-469-dual-four-barrel-carburetor-equipment-1143.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</guid>
										<title>1960 - 1961 Corvette: Zone Letter: Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-oil-filler-cap-and-crankcase-breather-1214.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Oil Filler Cap and Crankcase Breather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-oil-filler-cap-and-crankcase-breather-1214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-loss-of-oil-pressure-176.html</guid>
										<title>1962 Corvette: Service Bulletin: Loss of Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-loss-of-oil-pressure-176.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</guid>
										<title>1954 Corvette: Service Bulletin: New Valve Spring - High Lift Cam Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</link>
