<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-1984-corvettes-painted-with-1986-colors-for-general-managers-color-show-76.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-protective-transit-coating-for-exterior-paint-651.html</guid>
										<title>1991 Corvette: Service Bulletin: Protective Transit Coating for Exterior Paint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-protective-transit-coating-for-exterior-paint-651.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Cracks/Damage to Cowl Surface</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</guid>
										<title>1988 - 1989 Corvette:  Hood Rubs Air Conditioning Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1993-corvette-service-bulletin-rear-lift-window-hard-to-open-hinge-loose-to-glass-669.html</guid>
										<title>1984 - 1993 Corvette: Service Bulletin: Rear Lift Window Hard to Open/Hinge Loose to Glass</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1993-corvette-service-bulletin-rear-lift-window-hard-to-open-hinge-loose-to-glass-669.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-hood-latch-striker-bolt-649.html</guid>
										<title>1992 Corvette: Service Bulletin: Hood Latch Striker Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-hood-latch-striker-bolt-649.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-roof-panel-adjustment-procedures-661.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Roof Panel Adjustment Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-roof-panel-adjustment-procedures-661.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-chattering-wiper-blades-or-wipeability-646.html</guid>
										<title>1984 - 1996 Corvette: Service Bulletin: Chattering Wiper Blades or Wipeability</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-chattering-wiper-blades-or-wipeability-646.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-potential-paint-peeling-on-front-fascias-652.html</guid>
										<title>1991 Corvette: Service Bulletin: Potential Paint Peeling on Front Fascias</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-potential-paint-peeling-on-front-fascias-652.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-hood-will-not-open-cable-disconnection-648.html</guid>
										<title>1993 Corvette: Service Bulletin: Hood Will Not Open - Cable Disconnection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-hood-will-not-open-cable-disconnection-648.html</link>
