<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-corvette-hood-flutter-with-425-h-p-engine-752.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-difficulty-in-raising-door-window-756.html</guid>
										<title>1963 Corvette: Service Bulletin: Difficulty in Raising Door Window</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-difficulty-in-raising-door-window-756.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-chevrolet-inter-organization-letters-development-and-demise-of-the-corvette-coupe-exhaust-fan-1247.html</guid>
										<title>1964 - 1965 Corvette:  Chevrolet Inter-Organization Letters: Development and Demise of the Corvette Coupe Exhaust Fan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1965-corvette-chevrolet-inter-organization-letters-development-and-demise-of-the-corvette-coupe-exhaust-fan-1247.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-product-engineering-technical-information-loosening-of-door-window-regulator-assembly-1013.html</guid>
										<title>1963 Corvette:  Product Engineering Technical Information:  Loosening of Door Window Regulator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-product-engineering-technical-information-loosening-of-door-window-regulator-assembly-1013.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-corvette-hood-support-safety-hole-898.html</guid>
										<title>1964 Corvette:  Service News:  Corvette Hood Support Safety Hole</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-corvette-hood-support-safety-hole-898.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-corvette-convertible-top-protective-shipping-covers-800.html</guid>
										<title>1963 Corvette: Service Bulletin: Corvette Convertible Top Protective Shipping Covers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-corvette-convertible-top-protective-shipping-covers-800.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gm-of-canada-hood-lock-spring-assembly-871.html</guid>
										<title>1963 Corvette: Service Bulletin - GM of Canada: Hood Lock Spring Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gm-of-canada-hood-lock-spring-assembly-871.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-the-other-corvette-body-builder-a-o-smith-helps-st-louis-keep-up-with-production-248.html</guid>
										<title>1963 - 1967 Corvette: Technical Article:  The Other Corvette Body Builder - A.O. Smith Helps St. Louis Keep Up With Production</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-technical-article-the-other-corvette-body-builder-a-o-smith-helps-st-louis-keep-up-with-production-248.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-door-glass-outer-seal-strip-replacement-758.html</guid>
										<title>1963 - 1964 Corvette: Service Bulletin: Door Glass Outer Seal Strip Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-door-glass-outer-seal-strip-replacement-758.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-excessive-hood-release-effort-755.html</guid>
										<title>1964 Corvette: Service Bulletin: Excessive Hood Release Effort</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-excessive-hood-release-effort-755.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-hood-flutter-and-rapping-on-the-radiator-support-no-189-t-i-905.html</guid>
										<title>1965 Corvette: Chevrolet Engineering Service Letter:  Hood Flutter and Rapping on the Radiator Support (No. 189-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-hood-flutter-and-rapping-on-the-radiator-support-no-189-t-i-905.html</link>
