<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-corvette-personal-audio-link-pal-installation-for-vehicles-equipped-with-factory-navigation-u3u-75.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</guid>
										<title>2005 - 2016 Corvette: 15521 - Customer Advisory Letter - Side Door Release Operation - Phase 2 Mailing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Door Handle Release Button</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-door-handle-release-button-101.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</guid>
										<title>2005 (Canadian Corvettes Only): Recall 04096: Incorrect Air Bag Off Indicator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-premium-sound-system-265.html</guid>
										<title>2006 Corvette:  Electrical Schematic: Premium Sound System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-premium-sound-system-265.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-customer-satisfaction-program-keyless-access-system-inoperative-168.html</guid>
										<title>2008 Corvette: Customer Satisfaction Program: Keyless Access System Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-customer-satisfaction-program-keyless-access-system-inoperative-168.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</guid>
										<title>2005 Corvette: GM TechLink: Keyless Ignition System Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-keyless-ignition-system-information-346.html</link>
