										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</guid>
										<title>1980 - 1982 Corvette:  Service News:  Differential Side Bearing Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-positraction-chatter-1972-passenger-cars-and-10-series-trucks-825.html</guid>
										<title>1972 Corvette: Service News: Positraction Chatter - 1972 Passenger Cars and 10 Series Trucks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-positraction-chatter-1972-passenger-cars-and-10-series-trucks-825.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-shipping-block-removal-1975-corvettes-shipped-via-rail-873.html</guid>
										<title>1975 Corvette: Service News: Shipping Block Removal - 1975 Corvettes Shipped Via Rail</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-shipping-block-removal-1975-corvettes-shipped-via-rail-873.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-recall-towing-bracket-installation-798.html</guid>
										<title>1980 Corvette: Recall: Towing Bracket Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-recall-towing-bracket-installation-798.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</guid>
										<title>1978 - 1979 Corvette: Service News: Access to Right Upper Control Arm Attaching Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</guid>
										<title>1964 Corvette: Service News: Steering Ratios</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</guid>
										<title>1980 Corvette:  Service Bulletin:  Rear Wheel Spindle Yoke Snapping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-revised-1963-corvette-rear-wheel-spindle-1035.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Revised 1963 Corvette Rear Wheel Spindle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-revised-1963-corvette-rear-wheel-spindle-1035.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</guid>
										<title>1967 Corvette:  Engineering Service Letter Note:  Steering Shaft Upper Retaining Ring Removal on Telescoping Columns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</link>
