<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</guid>
										<title>1963 Corvette: Zone Letter: Propeller Shaft Balancing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-chevrolet-service-news-rear-spring-removal-service-update-1237.html</guid>
										<title>1963 - 1982 Corvette:  Chevrolet Service News:  Rear Spring Removal Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-chevrolet-service-news-rear-spring-removal-service-update-1237.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-engineering-service-letter-steering-effort-on-booster-type-power-steering-vehicles-1223.html</guid>
										<title>1963 - 1967 Corvette: Engineering Service Letter:  Steering Effort on Booster Type Power Steering Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-engineering-service-letter-steering-effort-on-booster-type-power-steering-vehicles-1223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-steering-shaft-lower-bearing-spacer-1058.html</guid>
										<title>1963 Corvette:  Field Service Engineering:  Steering Shaft Lower Bearing Spacer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-steering-shaft-lower-bearing-spacer-1058.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-revised-1963-corvette-rear-wheel-spindle-1035.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Revised 1963 Corvette Rear Wheel Spindle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-revised-1963-corvette-rear-wheel-spindle-1035.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</guid>
										<title>1967 Corvette:  Engineering Service Letter Note:  Steering Shaft Upper Retaining Ring Removal on Telescoping Columns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: In-Vehicle Corvette Steering Gear Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-rear-suspension-crossmember-isolation-mounts-pulling-loose-971.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Rear Suspension Crossmember Isolation Mounts Pulling Loose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-rear-suspension-crossmember-isolation-mounts-pulling-loose-971.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-lubrication-chart-490.html</guid>
										<title>1963 - 1964 Corvette: Lubrication Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-lubrication-chart-490.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-steering-dampener-control-744.html</guid>
										<title>1963 Corvette: Chevrolet Inter-Organization Letter: Steering Dampener Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-steering-dampener-control-744.html</link>
