<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-steering-dampener-control-744.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-lubrication-chart-490.html</guid>
										<title>1963 - 1964 Corvette: Lubrication Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-lubrication-chart-490.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</guid>
										<title>1964 Corvette: Service News: Steering Ratios</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-rear-suspension-crossmember-isolation-mounts-pulling-loose-971.html</guid>
										<title>1963 - 1965 Corvette:  Service Bulletin:  Rear Suspension Crossmember Isolation Mounts Pulling Loose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1965-corvette-service-bulletin-rear-suspension-crossmember-isolation-mounts-pulling-loose-971.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-production-information-new-options-j56-brakes-and-f40-heavy-duty-suspension-breakup-of-z06-performance-package-1152.html</guid>
										<title>1964 Corvette:  Production Information:  New Options - J56 Brakes and F40 Heavy Duty Suspension Breakup of Z06 Performance Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-production-information-new-options-j56-brakes-and-f40-heavy-duty-suspension-breakup-of-z06-performance-package-1152.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-chevrolet-service-news-rear-spring-removal-service-update-1237.html</guid>
										<title>1963 - 1982 Corvette:  Chevrolet Service News:  Rear Spring Removal Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-chevrolet-service-news-rear-spring-removal-service-update-1237.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</guid>
										<title>1963 Corvette: Service News: Hydraulic Steering Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</guid>
										<title>1963 - 1971 Corvette: Service News: Lubrication of Rear Wheel Inner Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: In-Vehicle Corvette Steering Gear Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-frame-specifications-257.html</guid>
										<title>1963 - 1967 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-frame-specifications-257.html</link>
