<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-steering-ratios-743.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-propeller-shaft-balancing-746.html</guid>
										<title>1963 Corvette: Chevrolet Inter-Organization Letter: Propeller Shaft Balancing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-chevrolet-inter-organization-letter-propeller-shaft-balancing-746.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: In-Vehicle Corvette Steering Gear Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-engineering-service-letter-steering-effort-on-booster-type-power-steering-vehicles-1223.html</guid>
										<title>1963 - 1967 Corvette: Engineering Service Letter:  Steering Effort on Booster Type Power Steering Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-engineering-service-letter-steering-effort-on-booster-type-power-steering-vehicles-1223.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Interim Production Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-interim-production-changes-1024.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</guid>
										<title>1963 Corvette: Service News: Hydraulic Steering Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-hydraulic-steering-hose-interference-745.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</guid>
										<title>1967 Corvette:  Engineering Service Letter Note:  Steering Shaft Upper Retaining Ring Removal on Telescoping Columns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</guid>
										<title>1963 Corvette: Zone Letter: Propeller Shaft Balancing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</guid>
										<title>1963 - 1971 Corvette: Service News: Lubrication of Rear Wheel Inner Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-frame-specifications-257.html</guid>
										<title>1963 - 1967 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-frame-specifications-257.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1974-corvette-service-news-corvette-rear-wheel-end-play-adjustment-and-inner-bearing-lubrication-747.html</guid>
										<title>1963 - 1974 Corvette: Service News: Corvette Rear Wheel End Play Adjustment and Inner Bearing Lubrication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1974-corvette-service-news-corvette-rear-wheel-end-play-adjustment-and-inner-bearing-lubrication-747.html</link>
