<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gear-block-out-and-high-shifting-effort-742.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-gear-shift-control-assembly-buzz-1103.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Gear Shift Control Assembly Buzz</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-gear-shift-control-assembly-buzz-1103.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-reliability-data-center-letter-poor-release-and-high-pedal-effort-1966-327-cid-corvette-engines-1100.html</guid>
										<title>1966 Corvette:  Reliability Data Center Letter:  Poor Release and High Pedal Effort - 1966 327 CID Corvette Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-reliability-data-center-letter-poor-release-and-high-pedal-effort-1966-327-cid-corvette-engines-1100.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-3-and-4-speed-transmission-clutch-gear-bearing-retainer-failure-963.html</guid>
										<title>1963 Corvette:  Service Bulletin:  3 and 4-Speed Transmission Clutch Gear Bearing Retainer Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-3-and-4-speed-transmission-clutch-gear-bearing-retainer-failure-963.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-periodically-lubricate-manual-transmission-shift-mechanism-sn-c-30-876.html</guid>
										<title>1963 - 1967 Corvette: Service News: Periodically Lubricate Manual Transmission Shift Mechanism (SN-C-30)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-periodically-lubricate-manual-transmission-shift-mechanism-sn-c-30-876.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-4-speed-transmission-removal-and-reinstallation-741.html</guid>
										<title>1964 Corvette: Service News: 1964 4-Speed Transmission Removal and Reinstallation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-4-speed-transmission-removal-and-reinstallation-741.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Transmission Shift Lever Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-powerglide-transmission-control-rod-adjustment-116.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Powerglide Transmission Control Rod Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-powerglide-transmission-control-rod-adjustment-116.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-manual-transmission-removal-48.html</guid>
										<title>1967 Corvette:  Service News: Corvette Manual Transmission Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-manual-transmission-removal-48.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-3-speed-transmission-problems-919.html</guid>
										<title>1963 - 1964 Corvette:  Service Bulletin:  3-Speed Transmission Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-3-speed-transmission-problems-919.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Reverse Lockout Mechanism Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</link>
