<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-4-speed-transmission-removal-and-reinstallation-741.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-periodically-lubricate-manual-transmission-shift-mechanism-sn-c-30-876.html</guid>
										<title>1963 - 1967 Corvette: Service News: Periodically Lubricate Manual Transmission Shift Mechanism (SN-C-30)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-periodically-lubricate-manual-transmission-shift-mechanism-sn-c-30-876.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-3-speed-transmission-problems-919.html</guid>
										<title>1963 - 1964 Corvette:  Service Bulletin:  3-Speed Transmission Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-bulletin-3-speed-transmission-problems-919.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-gear-shift-control-assembly-buzz-1103.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Gear Shift Control Assembly Buzz</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-gear-shift-control-assembly-buzz-1103.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</guid>
										<title>1962 - 1963 Corvette:  Service Bulletin:  Governor Rattle After Reverse Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-powerglide-transmission-control-rod-adjustment-116.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Powerglide Transmission Control Rod Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-powerglide-transmission-control-rod-adjustment-116.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-powerglide-transmission-governor-operational-check-958.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Powerglide Transmission Governor Operational Check</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-powerglide-transmission-governor-operational-check-958.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-powerglide-removal-and-reinstallation-740.html</guid>
										<title>1964 Corvette: Service News: 1964 Powerglide Removal and Reinstallation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-powerglide-removal-and-reinstallation-740.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Transmission Shift Lever Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-improved-vacuum-modulator-957.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Improved Vacuum Modulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-improved-vacuum-modulator-957.html</link>
