<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-audible-noise-in-radio-chevrolet-with-transistorized-ignition-80.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Audible Noise in Radio - Chevrolet with Transistorized Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-audible-noise-in-radio-chevrolet-with-transistorized-ignition-80.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Muncie Four Speed Transmission Design Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1967-corvette-delco-remy-service-bulletin-ignition-systems-940.html</guid>
										<title>1964 - 1967 Corvette:  Delco-Remy Service Bulletin:  Ignition Systems</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-production-information-price-change-am-fm-radio-1138.html</guid>
										<title>1963 Corvette:  Production Information:  Price Change - AM-FM Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-production-information-price-change-am-fm-radio-1138.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-rpo-k-66-wiring-diagram-for-breakerless-ignition-system-1196.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  RPO K-66 Wiring Diagram for Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-rpo-k-66-wiring-diagram-for-breakerless-ignition-system-1196.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Turn Signal Switch - Failure to Cancel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-technical-article-rear-bulb-re-incarnation-243.html</guid>
										<title>1966 Corvette: Technical Article:  Rear Bulb Re-incarnation</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-electric-window-motor-replacement-846.html</guid>
										<title>1967 Corvette: Service News: Corvette Electric Window Motor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-electric-window-motor-replacement-846.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
