<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</guid>
										<title>1965 Corvette: Service News:  Engine Removal Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-corvette-fuel-injection-cold-starting-procedure-736.html</guid>
										<title>1963 Corvette: Service News: Corvette Fuel Injection Cold Starting Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-corvette-fuel-injection-cold-starting-procedure-736.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</guid>
										<title>1966 - 1967 Corvette:  Service Bulletin:  Crankshaft to Water Pump Drive Belt Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</guid>
										<title>1963 - 1964 Corvette: Service News:  Radiator Lower Hose Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</guid>
										<title>1964 Corvette: Service Bulletin: Recalibration of Carter AFB Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 396-425 H.P. RPO L-78 Incorrect Build</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Top Radiator Inlet Hose Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-top-radiator-inlet-hose-interference-1004.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Corvette 427 Mark IV Engine Surge (No. 358-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
