<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-3x2-carburetor-to-manifold-gasket-728.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Corvette 427 Mark IV Engine Surge (No. 358-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</guid>
										<title>1964 Corvette: Service Bulletin: Recalibration of Carter AFB Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-service-bulletin-cooling-system-restrictions-symptoms-and-diagnosis-1131.html</guid>
										<title>1963 - 1982 Corvette:  Service Bulletin:  Cooling System Restrictions - Symptoms and Diagnosis</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</guid>
										<title>1963 Corvette:  Field Service Engineering:  Intake Manifold Baffle Rivet Hole Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Automatic Choke Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-automatic-choke-malfunction-1059.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</guid>
										<title>1966 - 1967 Corvette:  Service Bulletin:  Crankshaft to Water Pump Drive Belt Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</guid>
										<title>1964 Corvette: Service News: Servicing 1964 Corvette Fuel Injection Units</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</link>
