<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1976-corvette-service-bulletin-air-conditioning-compressor-drive-belt-to-radiator-hose-interference-721.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</guid>
										<title>1969 Corvette:  Service News:  Delcotron Battery Terminal Contacting Rocker Cover</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Gas Line Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Fuel Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-fuel-filter-953.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-1974-corvette-service-bulletin-engine-overheat-due-to-blocked-coolant-passage-in-the-cylinder-head-1115.html</guid>
										<title>1973 - 1974 Corvette:  Service Bulletin:  Engine Overheat Due to Blocked Coolant Passage in the Cylinder Head</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-1974-corvette-service-bulletin-engine-overheat-due-to-blocked-coolant-passage-in-the-cylinder-head-1115.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</guid>
										<title>1970 Corvette:  Service News:  1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Refrigerant Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</link>
