<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-service-bulletin-heater-hose-clamp-interference-with-a-c-evaporator-inlet-pipe-720.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-heater-and-air-conditioning-1190.html</guid>
										<title>1970 Corvette:  Service News:  Heater and Air Conditioning</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-heater-and-air-conditioning-1190.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Refrigerant Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-refrigerant-leak-1128.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-air-conditioning-equipped-vehicles-1172.html</guid>
										<title>1971 Corvette:  Service Bulletin:  Air Conditioning Equipped Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-air-conditioning-equipped-vehicles-1172.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</guid>
										<title>1973 Corvette: Service Bulletin: Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-condenser-and-receiver-dehydrator-removal-1228.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Condenser and Receiver-Dehydrator Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-condenser-and-receiver-dehydrator-removal-1228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-air-conditioning-compressor-noise-954.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Air Conditioning Compressor Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-air-conditioning-compressor-noise-954.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</guid>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</link>
