<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-rear-bow-lock-bolt-718.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cracking-of-the-plenum-at-the-right-hood-latch-plate-944.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Cracking of the Plenum at the Right Hood Latch Plate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cracking-of-the-plenum-at-the-right-hood-latch-plate-944.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-a-i-68-11-878.html</guid>
										<title>1968 Corvette: Inter-Organization Letter:  Water Leaks - 1968 Corvette Aero-Coupe and Convertible A.I. 68-11</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-a-i-68-11-878.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-removable-roof-panel-fit-972.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Removable Roof Panel Fit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-removable-roof-panel-fit-972.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</guid>
										<title>1968 Corvette:  Chevrolet Engineering Memo:  Window Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-1974-corvette-chevrolet-parts-bulletin-corvette-repair-kits-717.html</guid>
										<title>1971 - 1974 Corvette: Chevrolet Parts Bulletin: Corvette Repair Kits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-1974-corvette-chevrolet-parts-bulletin-corvette-repair-kits-717.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-thawing-frozen-door-locks-and-preventing-future-freezing-1083.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Thawing Frozen Door Locks and Preventing Future Freezing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-thawing-frozen-door-locks-and-preventing-future-freezing-1083.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-1970-corvette-folding-top-material-interference-with-lid-pin-support-980.html</guid>
										<title>1970 Corvette:  Service Bulletin:  1970 Corvette Folding Top Material Interference with Lid Pin Support</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-1970-corvette-folding-top-material-interference-with-lid-pin-support-980.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-auxiliary-hardtop-and-stowage-compartment-door-items-931.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Auxiliary Hardtop and Stowage Compartment Door Items</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-auxiliary-hardtop-and-stowage-compartment-door-items-931.html</link>
