<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-1974-corvette-chevrolet-parts-bulletin-corvette-repair-kits-717.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-enamel-paint-pilot-program-712.html</guid>
										<title>1980 Corvette: Service Bulletin: Enamel Paint Pilot Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-enamel-paint-pilot-program-712.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-front-fender-skirt-availability-1211.html</guid>
										<title>1972 Corvette:  Service News:  Front Fender Skirt Availability</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-front-fender-skirt-availability-1211.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1972-corvette-service-news-rear-bow-lock-spring-replacement-894.html</guid>
										<title>1968 - 1972 Corvette:  Service News:  Rear Bow Lock Spring Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1972-corvette-service-news-rear-bow-lock-spring-replacement-894.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1980-corvette-service-bulletin-refinishing-exterior-black-painted-moldings-715.html</guid>
										<title>1977 - 1980 Corvette: Service Bulletin: Refinishing Exterior Black Painted Moldings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1980-corvette-service-bulletin-refinishing-exterior-black-painted-moldings-715.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1978-corvette-service-bulletin-rear-bumper-cover-wavy-31.html</guid>
										<title>1977 - 1978 Corvette:  Service Bulletin:  Rear Bumper Cover Wavy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1978-corvette-service-bulletin-rear-bumper-cover-wavy-31.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-rear-bow-lock-bolt-718.html</guid>
										<title>1968 Corvette: Service Bulletin: Rear Bow Lock Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-rear-bow-lock-bolt-718.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</guid>
										<title>1968 Corvette: Service Bulletin: Lubrication of Window Regulator Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</link>
