<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1982-corvette-service-bulletin-enamel-paint-usage-and-repair-711.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1972-corvette-service-news-rear-bow-lock-spring-replacement-894.html</guid>
										<title>1968 - 1972 Corvette:  Service News:  Rear Bow Lock Spring Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1972-corvette-service-news-rear-bow-lock-spring-replacement-894.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-headlight-and-vacuum-line-component-schematic-1165.html</guid>
										<title>1972 Corvette:  Headlight and Vacuum Line Component Schematic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-headlight-and-vacuum-line-component-schematic-1165.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</guid>
										<title>1968 Corvette: Recall: Product Campaign No. 8005 Left Front Fender Skirt to Brake Pipe Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1976-corvette-service-news-1975-model-lock-sets-in-1976-vehicles-1120.html</guid>
										<title>1975 - 1976 Corvette:  Service News:  1975 Model Lock Sets in 1976 Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-1976-corvette-service-news-1975-model-lock-sets-in-1976-vehicles-1120.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</guid>
										<title>1968 Corvette:  Chevrolet Engineering Memo:  Window Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-seattle-zone-letter-1969-door-trim-identification-labels-926.html</guid>
										<title>1969 Corvette:  Seattle Zone Letter:  1969 Door Trim Identification Labels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-seattle-zone-letter-1969-door-trim-identification-labels-926.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-133.html</guid>
										<title>1973 Corvette: Service Bulletin: Rear Window Water Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-133.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1980-corvette-service-bulletin-refinishing-exterior-black-painted-moldings-715.html</guid>
										<title>1977 - 1980 Corvette: Service Bulletin: Refinishing Exterior Black Painted Moldings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1980-corvette-service-bulletin-refinishing-exterior-black-painted-moldings-715.html</link>
