<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</guid>
										<title>1974 - 1975 Corvette:  Service Bulletin:  Stripped Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</guid>
										<title>1980 Corvette: Service Bulletin: Propeller Shaft Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-new-warner-4-speed-released-interim-1974-production-1071.html</guid>
										<title>1974 Corvette:  Service News:  New Warner 4-Speed Released Interim 1974 Production</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-new-warner-4-speed-released-interim-1974-production-1071.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</guid>
										<title>1981 Corvette:  Service Bulletin:  Whistle or Whine in Reverse or Lo 1 at Idle - THM 350C (MX3)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
