<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-propeller-shaft-assemblies-704.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</guid>
										<title>1976 - 1990 Corvette: Service Bulletin: New On-Vehicle Service Procedure to Remove Rear Case or Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</guid>
										<title>1968 - 1969 Corvette:  Chevrolet Service Engineering Letter: Service Procedures for Clutch Gear Slinger on Muncie 4-Speed Passenger Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</guid>
										<title>1973 + Corvette: Service News: Gear Tooth Contact Pattern Check - All Rear Axle Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</guid>
										<title>1974 - 1975 Corvette:  Service Bulletin:  Stripped Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</guid>
										<title>1982 Corvette:  Service Bulletin:  Output Shaft Speedo Gear Clip Holes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</link>
