<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-improperly-installed-reverse-idler-shaft-roll-pin-611.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Improperly Installed Reverse Idler Shaft Roll Pin</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-improperly-installed-reverse-idler-shaft-roll-pin-611.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</guid>
										<title>1973 + Corvette: Service News: Gear Tooth Contact Pattern Check - All Rear Axle Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-new-warner-4-speed-released-interim-1974-production-1071.html</guid>
										<title>1974 Corvette:  Service News:  New Warner 4-Speed Released Interim 1974 Production</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-new-warner-4-speed-released-interim-1974-production-1071.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</guid>
										<title>1968 - 1969 Corvette:  Chevrolet Service Engineering Letter: Service Procedures for Clutch Gear Slinger on Muncie 4-Speed Passenger Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</guid>
										<title>1984 - 1989 Corvette:  Service Bulletin: Steering Gear Intermediate Shaft Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</guid>
										<title>1996 Corvette: Service Bulletin: 3 - 2 Part Throttle Downshift Flare</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</guid>
										<title>1995 - 1996 Corvette: Service Bulletin: Delayed Engagement (Replace Pump Cover Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</guid>
										<title>1976 - 1990 Corvette: Service Bulletin: New On-Vehicle Service Procedure to Remove Rear Case or Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</link>
