										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</guid>
										<title>1995 Corvette: Service Bulletin: 3 - 2 Downshift Flare (Reflash Control Module)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-4l60-low-reverse-clutch-new-plate-available-607.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: 4L60 Low &amp; Reverse Clutch New Plate Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-4l60-low-reverse-clutch-new-plate-available-607.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</guid>
										<title>1968 - 1971 Corvette:  Service News:  Front Servo and Front Accumulator Piston Identification - Turbo Hydra-Matic 400 Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</guid>
										<title>1968 - 1969 Corvette:  Chevrolet Service Engineering Letter: Service Procedures for Clutch Gear Slinger on Muncie 4-Speed Passenger Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-chevrolet-service-engineering-letter-service-procedures-for-clutch-gear-slinger-on-muncie-4-speed-passenger-transmissions-33.html</link>
