<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</guid>
										<title>1995 - 1996  Corvette: Service Bulletin: Transmission Fluid Leak From Pump Body</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Click/Whine in 3rd/4th Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-improperly-installed-reverse-idler-shaft-roll-pin-611.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Improperly Installed Reverse Idler Shaft Roll Pin</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-improperly-installed-reverse-idler-shaft-roll-pin-611.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-differences-between-first-and-second-generation-zf-6-speed-transmissions-605.html</guid>
										<title>1989 - 1996 Corvette: Differences between First and Second Generation ZF 6-Speed Transmissions</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</guid>
										<title>1994 Corvette: Service Bulletin: Garage Shift Delay Engagement (New Garage Shift Package)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</link>
