<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-1974-corvette-chevrolet-parts-bulletin-corvette-repair-kits-717.html</guid>
										<title>1971 - 1974 Corvette: Chevrolet Parts Bulletin: Corvette Repair Kits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-1974-corvette-chevrolet-parts-bulletin-corvette-repair-kits-717.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-headlight-and-vacuum-line-component-schematic-1165.html</guid>
										<title>1972 Corvette:  Headlight and Vacuum Line Component Schematic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-headlight-and-vacuum-line-component-schematic-1165.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Delcotron Noise (Moan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</guid>
										<title>1972 Corvette:  Service Bulletin:  Blown Thermal Fuse Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-bulletin-blown-thermal-fuse-diagnosis-1127.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-133.html</guid>
										<title>1973 Corvette: Service Bulletin: Rear Window Water Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-133.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</guid>
										<title>1968 Corvette Convertible:  Engineering Service Letter:  Rear Courtesy Light Shorting Out</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-supplement-to-a-i-68-11-1112.html</guid>
										<title>1968 Corvette: Inter-Organization Letter:  Water Leaks - 1968 Corvette Aero-Coupe and Convertible Supplement to A.I. 68-11</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-supplement-to-a-i-68-11-1112.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1972-corvette-service-news-rear-bow-lock-spring-replacement-894.html</guid>
										<title>1968 - 1972 Corvette:  Service News:  Rear Bow Lock Spring Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1972-corvette-service-news-rear-bow-lock-spring-replacement-894.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-rear-bow-lock-bolt-718.html</guid>
										<title>1968 Corvette: Service Bulletin: Rear Bow Lock Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-rear-bow-lock-bolt-718.html</link>
