<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-removal-of-corvette-front-speakers-695.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-collectors-edition-service-bulletin-white-deposit-on-door-trim-panel-964.html</guid>
										<title>1982 Corvette Collectors Edition:  Service Bulletin:  White Deposit on Door Trim Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-collectors-edition-service-bulletin-white-deposit-on-door-trim-panel-964.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1990-corvette-service-bulletin-loose-carpet-on-side-wall-trim-pads-repair-procedure-683.html</guid>
										<title>1980 - 1990 Corvette: Service Bulletin: Loose Carpet on Side Wall Trim Pads (Repair Procedure)</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-bulletin-instrument-cluster-area-squeak-986.html</guid>
										<title>1978 - 1980 Corvette:  Service Bulletin:  Instrument Cluster Area Squeak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-bulletin-instrument-cluster-area-squeak-986.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</guid>
										<title>1974 - 1975 Corvette: Service Bulletin: Stripped Speedometer Driven Gear, 1974-1975 Corvette with 4-Spd. Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-inspection-and-realignment-of-the-energy-absorbing-steering-column-923.html</guid>
										<title>1967 Corvette:  Service News:  Inspection and Realignment of the Energy Absorbing Steering Column</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-inspection-and-realignment-of-the-energy-absorbing-steering-column-923.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</guid>
										<title>1981 Corvette: Service Bulletin: Glow Around Wiper Switch Rework Wiper Switch Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</guid>
										<title>1969 Corvette:  Service News:  Directional Signal Switch Removal and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-1969-corvette-steering-column-control-lock-tube-housing-cover-added-922.html</guid>
										<title>1969 Corvette:  Service News:  1969 Corvette Steering Column - Control Lock Tube Housing Cover Added</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-1969-corvette-steering-column-control-lock-tube-housing-cover-added-922.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html</guid>
										<title>1969 - 1970 Corvette: Service Bulletin: Odometer Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-anti-reversing-and-telltale-odometers-921.html</guid>
										<title>1969 Corvette:  Service News:  Anti-Reversing and Telltale Odometers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-anti-reversing-and-telltale-odometers-921.html</link>
