<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2011-corvette-gm-techlink-head-up-display-conditions-69.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</guid>
										<title>2005 (Canadian Corvettes Only): Recall 04096: Incorrect Air Bag Off Indicator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Misfire DTCs P0300, P1380, P1381 and Catalytic Converter Damage Due to Installation of Alarm Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-misfire-dtcs-p0300-p1380-p1381-and-catalytic-converter-damage-due-to-installation-of-alarm-systems-194.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-camapaign-service-active-handling-92.html</guid>
										<title>2005 - 2006 Corvette: Camapaign: Service Active Handling</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-camapaign-service-active-handling-92.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-diagnostic-trouble-codes-224.html</guid>
										<title>1997 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-diagnostic-trouble-codes-224.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</guid>
										<title>2002 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-diagnostic-trouble-codes-228.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-change-in-the-gm-nav-disc-update-program-180.html</guid>
										<title>2008 Corvette: Service Bulletin: Change in the GM Nav Disc Update Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-service-bulletin-change-in-the-gm-nav-disc-update-program-180.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</guid>
										<title>1997 - 2000 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-diagnostic-trouble-codes-421.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</guid>
										<title>2002 Corvette: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</guid>
										<title>2003 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2003-corvette-diagnostic-trouble-codes-227.html</link>
