										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Use of 1976 Model Ignition Key Sets in 1977 Chevrolet Passenger Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Generator Noise (Moan) at Idle with Air Conditioning On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-product-campaign-86co2-a-reissue-vehicle-anti-theft-system-vats-1016.html</guid>
										<title>1986 Corvette:  Product Campaign 86CO2(a) Reissue: Vehicle Anti Theft System (VATS)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-product-campaign-86co2-a-reissue-vehicle-anti-theft-system-vats-1016.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</guid>
										<title>1979 Corvette:  Service News:  Corvette Auxiliary Cooling Fan Wiring Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</link>
