<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</guid>
										<title>1976 - 1990 Corvette: Service Bulletin: New On-Vehicle Service Procedure to Remove Rear Case or Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</guid>
										<title>1968 Corvette: Service Bulletin: Driveline Clicking or Snapping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-chevrolet-service-news-instrument-panel-gauge-bezel-1263.html</guid>
										<title>1968 - 1971 Corvette:  Chevrolet Service News: Instrument Panel Gauge Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-chevrolet-service-news-instrument-panel-gauge-bezel-1263.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html</guid>
										<title>1969 - 1970 Corvette: Service Bulletin: Odometer Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-anti-reversing-and-telltale-odometers-921.html</guid>
										<title>1969 Corvette:  Service News:  Anti-Reversing and Telltale Odometers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-anti-reversing-and-telltale-odometers-921.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-1969-corvette-steering-column-control-lock-tube-housing-cover-added-922.html</guid>
										<title>1969 Corvette:  Service News:  1969 Corvette Steering Column - Control Lock Tube Housing Cover Added</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-1969-corvette-steering-column-control-lock-tube-housing-cover-added-922.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</guid>
										<title>1968 - 1971 Corvette:  Service News:  Front Servo and Front Accumulator Piston Identification - Turbo Hydra-Matic 400 Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</link>
