										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</guid>
										<title>1981 Corvette: Service Bulletin: Glow Around Wiper Switch Rework Wiper Switch Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</guid>
										<title>1994 - 1996 Corvette:  Service Bulletin:  Door Trim Arm Rest Lid Hard to Open or Close, Hinge Binding (Replace Hinge)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-seat-adjuster-excessive-movement-511.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Power Seat Adjuster Excessive Movement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-seat-adjuster-excessive-movement-511.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</guid>
										<title>1988 Corvette: Service Bulletin: 1988 Anniversary Model: Discolored Door Armrest</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</guid>
										<title>1992 Corvette: Recall: Instrument Panel/Left Hand Lower Trim/Brake Pedal Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-instrument-panel-left-hand-lower-trim-brake-pedal-interference-304.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-chevrolet-service-news-instrument-panel-gauge-bezel-1263.html</guid>
										<title>1968 - 1971 Corvette:  Chevrolet Service News: Instrument Panel Gauge Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-chevrolet-service-news-instrument-panel-gauge-bezel-1263.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html</guid>
										<title>1969 - 1970 Corvette: Service Bulletin: Odometer Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
