<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Water Entry Into Fuel Tank (#1092)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-water-entry-into-fuel-tank-1092-1125.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</guid>
										<title>1970 Corvette:  Service News:  1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</guid>
										<title>1974 Corvette: Service Bulletin: Soft Push Rod Guides</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</guid>
										<title>1963 - 1970 Corvette:  Service News:  Heavy Duty Positraction Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1970-corvette-service-news-heavy-duty-positraction-unit-1207.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</guid>
										<title>1973 Corvette:  Service Bulletin:  Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</guid>
										<title>1969 Corvette:  Service News:  Delcotron Battery Terminal Contacting Rocker Cover</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-delcotron-battery-terminal-contacting-rocker-cover-1022.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-choke-and-hot-restart-problems-930.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Choke and Hot Restart Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-choke-and-hot-restart-problems-930.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</guid>
										<title>1976 Corvette:  Parts Chart:  Delco Quadrajet Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Cold Start Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</link>
