<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-information-on-state-emission-testing-for-all-models-681.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</guid>
										<title>1981 Corvette: Service Bulletin: Poor Engine Performance, Catalytic Converter Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</guid>
										<title>1992 - 1996 Corvette: Tech Article: Quietly Powerful: How to Build a C4 LT1/4/5 Exhaust that Gains 28 hp and...is Quiet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rear-exhaust-hanger-bolt-falls-out-515.html</guid>
										<title>1985 Corvette: Service Bulletin: Rear Exhaust Hanger Bolt Falls Out</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rear-exhaust-hanger-bolt-falls-out-515.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-engine-ticking-noise-check-exhaust-manifold-bolts-514.html</guid>
										<title>1992 Corvette: Service Bulletin: Engine Ticking Noise - Check Exhaust Manifold Bolts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-engine-ticking-noise-check-exhaust-manifold-bolts-514.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</guid>
										<title>1973 Corvette:  Service Bulletin:  Exhaust Manifold to Air Conditioning Refrigerant Hose Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-to-air-conditioning-refrigerant-hose-clearance-1134.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: Tail Pipe Smoke on Startup</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1998-corvette-service-bulletin-paint-peeling-from-muffler-513.html</guid>
										<title>1993 - 1998 Corvette: Service Bulletin: Paint Peeling From Muffler</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1998-corvette-service-bulletin-paint-peeling-from-muffler-513.html</link>
