<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-service-bulletin-cooling-system-restrictions-symptoms-and-diagnosis-1131.html</guid>
										<title>1963 - 1982 Corvette:  Service Bulletin:  Cooling System Restrictions - Symptoms and Diagnosis</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Rear Axle Identification Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-rear-axle-identification-revision-1169.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-inadequate-cooling-1025.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Inadequate Cooling</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-inadequate-cooling-1025.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-product-safety-campaign-fuel-tank-return-line-tube-fitting-leakage-1241.html</guid>
										<title>1974 Corvette:  Product Safety Campaign:  Fuel Tank Return Line Tube Fitting Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-product-safety-campaign-fuel-tank-return-line-tube-fitting-leakage-1241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</guid>
										<title>1982 Corvette:  Service News:  Fuel Filter Usage and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</guid>
										<title>1981 Corvette: Service Bulletin: Poor Engine Performance, Catalytic Converter Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-poor-engine-performance-catalytic-converter-repair-682.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
