										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1982-corvette-parking-brake-alarm-components-and-part-numbers-1187.html</guid>
										<title>1953 - 1982 Corvette:  Parking Brake Alarm Components and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1982-corvette-parking-brake-alarm-components-and-part-numbers-1187.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-tamper-resistant-choke-1170.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Tamper Resistant Choke</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-tamper-resistant-choke-1170.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-mono-and-stereo-radio-system-190.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Mono and Stereo Radio System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-mono-and-stereo-radio-system-190.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</guid>
										<title>1975 Corvette:  Service News:  Radiator and Fan Shroud Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Delcotron Noise (Moan)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-delcotron-noise-moan-1077.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</guid>
										<title>1968 Corvette Convertible:  Engineering Service Letter:  Rear Courtesy Light Shorting Out</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-convertible-engineering-service-letter-rear-courtesy-light-shorting-out-1006.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-valve-rocker-arm-stud-replacement-1208.html</guid>
										<title>1970 Corvette:  Service News:  Valve Rocker Arm Stud Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-valve-rocker-arm-stud-replacement-1208.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-water-pump-bearing-and-or-shaft-failures-1020.html</guid>
										<title>1970 Corvette:  Service Bulletin:  Water Pump Bearing and/or Shaft Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-water-pump-bearing-and-or-shaft-failures-1020.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
