<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</guid>
										<title>1988 - 1989 Corvette:  Hood Rubs Air Conditioning Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Diagnosing Low Tire Pressure Warning System Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-zr-1-service-bulletin-lack-of-wide-open-throttle-engine-underpower-479.html</guid>
										<title>1992 Corvette ZR-1: Service Bulletin: Lack of Wide Open Throttle Engine Underpower</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-zr-1-service-bulletin-lack-of-wide-open-throttle-engine-underpower-479.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-differences-between-first-and-second-generation-zf-6-speed-transmissions-605.html</guid>
										<title>1989 - 1996 Corvette: Differences between First and Second Generation ZF 6-Speed Transmissions</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</guid>
										<title>1988 - 1992 Corvette: Service Bulletin: A/C Compressor Sealing Washer (New Design)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-technical-article-lt5-secondary-port-operation-vacuum-diagnosis-482.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Technical Article: LT5 Secondary Port Operation &amp; Vacuum Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-technical-article-lt5-secondary-port-operation-vacuum-diagnosis-482.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</guid>
										<title>1992 - 1996 Corvette: Tech Article: Quietly Powerful: How to Build a C4 LT1/4/5 Exhaust that Gains 28 hp and...is Quiet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</link>
